landonwood20
Everything posted by landonwood20
  1. My banshee started making some no so pleasent noises, it turns out the three screws that hold the stator to the timing Plate had rattled loose and we're catching on the flywheel. A little loctite and haven't had a problem since.
  2. It was one off of eBay. Runs good now just got done finishing the break in.
  3. Couldnt get the thing to start last week took it to the builder turns out the fly wheel that i purchased was bad and a new flywheel and it started right up. going to pick it up today.
  4. I haven't checked that yet but I will when time allows. Elevation is 1300' what should the pilot be? I have kicked it over for 5 min and won't start.
  5. It has pro circuit pipes, trail porting, airbox with no lid, proflow airbox plate and k&n filter. It had a 310 main jet when I pulled the carb apart and the needle is on the middle clip.
  6. The shop I was gonna take it to is full until monday, so I pull started the banshee and got it to run but if I let the throttle get below 1/4 throttle it would sputter and die out. Is this a jetting issue?
  7. Well I pulled the plug boots off grounded the plug just to see if the plug boot was the problem and what do you know bright blue spark. Taking it to the shop where the engine work was done to have put it on the dyno after new boots are installed. I will post the results when I get it back.
  8. I installed the new wiring harness, along with the Ignition coil, still no spark. Starting to think that stator is the problem because I am using the same cdi box and it ran before the rebuild.
  9. Here soon I will order his with the dc conversion, is the one racetech makes any good?
  10. Race tech stators, are the best ones you can buy?
  11. And I finally got the stator to read consistently after I pulled the stator cover off and wiggled the wires a bit. In the future I plan on getting rid of the Chinese POS.
  12. I got to looking at my harness wires are rubbed bare in multiple spots I ordered a new wiring harness from kompulsive along with new coil. I Accidently ripped the wire out of the stock coil.I will try it with the new harness and coil and report back to yall
  13. I recently had some troubles with my wiring harness, I was doing some reading and decided to go with Kompulsive concepts wiring harness. On a Sunday Cory answered every question that I needed answered, as well as getting the parts I ordered to the shipping distributer the same day. If you want some of the best customer service he is the man to go to.
  14. I am pretty sure it is one off of eBay that is sold by caltric.
  15. So I recently just got my engine back from jsr performance. Got every dropped back into the frame and no spark. I tested from green to red on the stator plug and got 14ohms I tested from white with red to white with green and got no reading at all. Any suggestions as to what might be wrong? Or is the brand new stator bad? Thanks for the help.
  16. Awesome, make buying them 10x easier thanks for the help.
  17. Yes, so I can buy any year and they will all fit
  18. Are the gears the same for every year?
  19. If it weren't for one of the teeth being wedged in the gears I probably would have never know it happened. What should a set of gears cost?
  20. Well I split the case only to find a few sheared transmission teeth.
  21. Well I drained the oil this evening and there wound up being no metal shavings in the transmission oil. I am starting to think it may be shift forks? Also even when the clutch lever is pulled it still acts like it is in gear and won't let the back tires spin freely.
  22. Do you still have a roller without plastics? What year of rollers also, thanks.
  23. Yes I have all the tools and knowledge to take it apart and put it back together, I haven't worked on banshees much though.
  24. Ok thank you when I get back for Colorado I will drain the oil and get back with you guys, thanks for the help, any idea on what it would cost to get that fixed?
