I have an oem stator just for the wrong year :( and I'm not gonna chip it up to change the plug
Corey at compulsive koncepts has adapters to swap over stators and harness. See if he has your years matched up
Didn't see that Gary posted ^^^^ already.
Thanks for chiming in. I did t have his screen name correct. Lol. Close
RaceTech stators FTW!
  • Like 1
Shouldn't matter if It's wet. I see stockers coated in rust that keep on goin. Ditch the junk aftermarket. Buy OEM, and guard it with your life. Maybe beg Gary to rewind your cunty Ching Chong ebay one.
  • Like 1
 I have had a similar problem with my stator. It seemed I was getting water inside the stator cover after I washed it. I had a stator go bad on me from that happening while riding.... this happened over the fourth of july. I replaced the stator with a good OEM used one and used RTV on the cover, the gasket and the case to seal it for good. When I tore the motor down this past weekend no water in the stator. When I put the parts back on I'll be using a new stator cover gasket and black RTV on all mating surfaces. I replaced the black philips head screws for the stainless allen screws with small washers and lock washers. I used RTV on the threads too, and harness grommet.
Edited by salmon_slayer06
^^^ troybrock knows how to seal his stator side cover..........................................and how to do a leak down test! banghead
I just left the cover off for a couple days, went down to see if anything changed before I ordered a stator and wala, kicked it over and had spark.
If this happens to you just let it air dry for a while before calling it dead.
