MoronG Posted August 8, 2014 Report Posted August 8, 2014 Sorry for ruining your post Troy it wasn't my intention I'm out.. Quote
TroyBrock Posted August 8, 2014 Author Report Posted August 8, 2014 paint that fucker! Getting old but only because I need an actual answer Quote
bigweav81 Posted August 8, 2014 Report Posted August 8, 2014 does it only do it when or after its been wet? Quote
TroyBrock Posted August 8, 2014 Author Report Posted August 8, 2014 After, but I think it has died on me once while riding it and it was the stator that caused it. The flywheel cover seal was on and the cover was tight so I'm not sure how water got in there; I do have the little rubber seal next to the sprocket, not sure exactly what it's called but it's there. Quote
bigweav81 Posted August 8, 2014 Report Posted August 8, 2014 reason I ask, I know a buddy of mine replaced his cdi, coil, flywheel, plug caps, voltage regulator, and his bike would still start sometimes, and sometimes not. replaced his wiring harness and it fixed it. idk if he had a bad spot he was to dumb, drunk, or high to see but that was his problem. Quote
TroyBrock Posted August 9, 2014 Author Report Posted August 9, 2014 I'm 99% positive that it's the stator. I've personally gone through the wire harness twice, swapped cdi, coil and all the other goodies just to have it be the brand new stator I bought. My question is if the stator gets wet is it done for or can you dry it out? Quote
bigweav81 Posted August 9, 2014 Report Posted August 9, 2014 fuck it jump in shoutbox, a lot of experienced guys on right now. entertaining the suspected troller matt, and good luck troy Quote
TroyBrock Posted August 9, 2014 Author Report Posted August 9, 2014 Is it an oem stator ??? No. I bought the quad and it already had a crappy aftermarket one, which I replaced with another crappy aftermarket one. I didn't except much out of it but I figured it last more than one ride. Quote
sheerider1026 Posted August 9, 2014 Report Posted August 9, 2014 Hahahaha. Yea. The problem is the cheap stator. A GOOD stator won't miss a beat. Even when it's wet!!! Quote
hp2000 Posted August 9, 2014 Report Posted August 9, 2014 You are a victim of crappy aftermarket stators lol Quote
TroyBrock Posted August 9, 2014 Author Report Posted August 9, 2014 (edited) I have an oem stator just for the wrong year and I'm not gonna chip it up to change the plug Edited August 9, 2014 by TroyBrock Quote
TroyBrock Posted August 9, 2014 Author Report Posted August 9, 2014 Case closed. Yup, thanks guys. Quote
hp2000 Posted August 9, 2014 Report Posted August 9, 2014 Sacrifices must be made to diagnose your problem. Quote
