Burnsidebancheata Posted August 5, 2014 Report Posted August 5, 2014 So, many of you know that I am rebuilding my banshee... If a good chunk of your piston was to snap off.. how many of you would open bottom end to check components? Quote
mhoksch Posted August 5, 2014 Report Posted August 5, 2014 If a chunk of your piston broke off, how could you NOT open up the bottom end? That's just asking for more problems. Sent from my XT901 using Tapatalk Quote
Larry's Shee Posted August 5, 2014 Report Posted August 5, 2014 99.999999999999999999999999999999999999999999999 % would/will, got to be an odd ball somewhere Quote
bigweav81 Posted August 5, 2014 Report Posted August 5, 2014 I didn't my first time..............................then a great guy on here told me, goddamn don't be a fucking lazy ass so on and so on. so 48 hrs later I did, hell he had me feeling so guilty I couldn't even start it , let alone ride it. rh side piston was missing about a half an inch of crown, but nothing in bottom end luckily. Im still an odd ball though. Quote
Burnsidebancheata Posted August 6, 2014 Author Report Posted August 6, 2014 Alright, thank you all. I am being told so many different things. I really do not want to open the bottom end and fuck something up, ya know? So that is why I am asking. I was told to just simply drain and check for metal frags because you may cause more problems tearing down the bottom end. I am not a engine expert. Quote
trickedcarbine Posted August 6, 2014 Report Posted August 6, 2014 Dude.... Just take it apart. If you don't find anything, great. At the very minimum you will have a completely fresh motor that SHOULD last. Or, you could chance it, put it together and have a catastrophe that means you not only gotta redo the top end yet again, but probably get stuck tearing the cases open any way. You're not just looking for the piece to be floating around. You're looking for fragmented/molten aluminum in the crank bearings and the big end of the rod. Quote
mhoksch Posted August 6, 2014 Report Posted August 6, 2014 The whole "draining" idea is worthless. That only drains the transmission oil. You need to be looking for pieces/damage in by the crank. The ONLY good way to do that is to split the cases. Sent from my XT901 using Tapatalk Quote
bansman76 Posted August 6, 2014 Report Posted August 6, 2014 I agree with the majority here, split them cases just to be safe and peace of mind lol. I'm in Richmond so If your unsure about splitting them and want/need help let me now Quote
imbill Posted August 6, 2014 Report Posted August 6, 2014 Dont chance it SPLIT the cases !!!!!!!! Quote
Burnsidebancheata Posted August 6, 2014 Author Report Posted August 6, 2014 I agree with the majority here, split them cases just to be safe and peace of mind lol. I'm in Richmond so If your unsure about splitting them and want/need help let me nowRichmond is not far at all... That would be nice! Sent from my Desire HD using Tapatalk 2 Quote
