Jgspahn Posted August 9, 2014 Author Report Posted August 9, 2014 Leak down again Not trying to argue, just wondering why. Nothing has changed since the last one . Quote
Jgspahn Posted August 9, 2014 Author Report Posted August 9, 2014 What about fuel supply? have you checked flow out of the petcock? cleaned the intank screen? Clear gas lines.. they seem to be running fine. Quote
Jgspahn Posted August 9, 2014 Author Report Posted August 9, 2014 Slides in backwards? The little cut out goes in front correct Quote
turbowrenchhead Posted August 9, 2014 Report Posted August 9, 2014 The cut out of the slide faces the air filter side of the carb or the inlet of the carb. Quote
Jgspahn Posted August 9, 2014 Author Report Posted August 9, 2014 If the fucking thing won't fire up you must have an issue with the pilot circuit. You also say it won't stay running at idle. Pilot. Check it better.Took the carbs apart and cleaned them this morning. The right side carb pilot had trash in it.. nice job Tyler. I haven't put them back in yet cause the ole lady put me on baby duty while she goes and does lowly woman things.. I'll get them back on in an hour or so and see where we are. Quote
Jgspahn Posted August 9, 2014 Author Report Posted August 9, 2014 The cut out of the slide faces the air filter side of the carb or the inlet of the carb. that's how they are Quote
03DMshee Posted August 9, 2014 Report Posted August 9, 2014 the ole lady put me on baby duty while she goes and does lowly woman things... Sounds like you gotta remind the hen who the ROOSTER is...... Quote
Jgspahn Posted August 9, 2014 Author Report Posted August 9, 2014 Sounds like you gotta remind the hen who the ROOSTER is...... Gotta pick your battles lol Quote
trickedcarbine Posted August 9, 2014 Report Posted August 9, 2014 Wakey wakey baby........ BRAAAAP. Quote
turbowrenchhead Posted August 9, 2014 Report Posted August 9, 2014 (edited) I dumped the last women that gave me a hard time about spending $ on my quads and going on trips. Now I gots me one that loves to ride. When she sees me pulling an engine apart she thinks its HOT! I've been with this one for almost a year now and we haven't got to go on a ride together alone. Finally next weekend we are going to northern wi for some riding. Edited August 9, 2014 by turbowrenchhead Quote
trickedcarbine Posted August 9, 2014 Report Posted August 9, 2014 ^ going to be cheated on with grizzly bear....... Quote
Jgspahn Posted August 9, 2014 Author Report Posted August 9, 2014 https://www.dropbox.com/s/wlvh3tz7mu03mga/20140809_103341.mp4 Check it out.. Thanks everybody Bogs a little the very first time you touch the throttle, then doesn't after that.... what's that Quote
turbowrenchhead Posted August 9, 2014 Report Posted August 9, 2014 Perhaps its loaded up. I've had that happen before if I let it idle for a bit, it will bog when you hit the throttle. Quote
Jgspahn Posted August 9, 2014 Author Report Posted August 9, 2014 Perhaps its loaded up. I've had that happen before if I let it idle for a bit, it will bog when you hit the throttle. What does loaded up mean Quote
turbowrenchhead Posted August 9, 2014 Report Posted August 9, 2014 Cylinder richens up and it takes a couple revs to clean them out. Quote
