So I just did top and bottom end re build and when I put the Transmission back in I put them in correctly with the Cir clips and seals and they rolled together... Then the crank sealed my Engine, and then the primary drive shaft and clutch basket and clutch plates... Now the bike is hesitating to shift into gear and I followed step by step from the Service Manual... Please help 5uge5y2a.jpgtyde6ebu.jpg
You are just doing this by hand without the motor running I am guessing? Does it shift all the gears just feels weird to you?
Same way you expect a chick to stroke ya nuts while she blows ya, the banshee trans is the same. You gotta tweak the shaft while you diddle the shifter. Problem solved.
  • Like 2
You might as well throw that flywheel in the trash now before it causes damage to your crank.
If that's a Ricky Stator, you can just throw out the whole set-up.
