AirForceBanshee
Everything posted by AirForceBanshee
  1. Looking to buy Brand new Sent from my iPhone using Tapatalk
  2. Thanks for the help guys. Sent from my iPhone using Tapatalk
  3. - No Spark - As everyone knows I've been for a week tracing down this Problem... I have a Brand new Wiring Harness, Race Tech stator put in Yesterday, New OEM Light Kill switch, and ordering another CDI and Ignition Coil - Just returning the Ricky stator, CDI and Ignition Coil.. Duds - Everything's been resistance checked and all wires I believe are correctly in place... - Been at a Dealer and a ATV Shop 3x -Need to know what goes where Sent from my iPhone using Tapatalk
  4. Still have? Sent from my iPhone using Tapatalk
  5. Yes I believe so everything else is new and those parts are Caltric which sell Ricky Stators which I am returning. Sent from my iPhone using Tapatalk
  6. Not getting spark and really sick of these electrical problems. Sent from my iPhone using Tapatalk
  7. What part is this And could it cause no spark? If it's not connected Sent from my iPhone using Tapatalk
  8. Oh jeez Sent from my iPhone using Tapatalk
  9. Came with them Sent from my iPhone using Tapatalk
  10. Just felt weird but working now Sent from my iPhone using Tapatalk
  11. Any suggestions? Sent from my iPhone using Tapatalk
  12. Sent from my iPhone using Tapatalk
  13. My 2003 Banshee I rebuilt I just dropped off at the shop to have my Carbs tuned/jetted and I wanted to find out what Jets to Put in or Order. 1)Elevation - 600 ft 2)Temp - 60,70 & 80 3)Exhaust - FnF Fatty & Powercore 2 Silencers. 4)PWK 28 mm Carburetors. 5) UNI Stage 2 Air Filters (No box) 6)Fuel - Premium 7)Engine Bore & Hone - 64.50 mm Sent from my iPhone using Tapatalk
  14. Ok Sent from my iPhone using Tapatalk
  15. And it's bore and honed .50 over brand new Pistons Sent from my iPhone using Tapatalk
  16. PWK 28 MM and I used Super fuel 40/1 Sent from my iPhone using Tapatalk
  17. Main jet #? 600 elevation 70-85 degrees... Stage 2 air filters FNF Exhaust and Fnf power core 2 silencers. Sent from my iPhone using Tapatalk
  18. I'm about to Check Sent from my iPhone using Tapatalk
  19. So I just did top and bottom end re build and when I put the Transmission back in I put them in correctly with the Cir clips and seals and they rolled together... Then the crank sealed my Engine, and then the primary drive shaft and clutch basket and clutch plates... Now the bike is hesitating to shift into gear and I followed step by step from the Service Manual... Please help Sent from my iPhone using Tapatalk
  20. Sent from my iPhone using Tapatalk
  21. As you know I'm Having Electrical problems I'm not very sure which plug to connect it to.. The Harness only has Female ends but their the right Color. I have no spark with the Yellow and Red wire and black wire. Sent from my iPhone using Tapatalk
  22. What would that do? Sent from my iPhone using Tapatalk
  23. Suggestions anyone? Sent from my iPhone using Tapatalk
  24. Bought a brand new Wiring Harness, Stator, Spark plug Harness and new Plugs and installed a OEM kill switch no spark compression is 125 Sent from my iPhone using Tapatalk
  25. Damn.. Sent from my iPhone using Tapatalk
