AirForceBanshee Posted July 22, 2014 Report Posted July 22, 2014 So I just did top and bottom end re build and when I put the Transmission back in I put them in correctly with the Cir clips and seals and they rolled together... Then the crank sealed my Engine, and then the primary drive shaft and clutch basket and clutch plates... Now the bike is hesitating to shift into gear and I followed step by step from the Service Manual... Please help Sent from my iPhone using Tapatalk Quote
Larry's Shee Posted July 22, 2014 Report Posted July 22, 2014 Are you turning sprocket shaft while trying to shift? Quote
AirForceBanshee Posted July 22, 2014 Author Report Posted July 22, 2014 Are you turning sprocket shaft while trying to shift?I'm about to Check Sent from my iPhone using Tapatalk Quote
BUILDER Posted July 22, 2014 Report Posted July 22, 2014 You are just doing this by hand without the motor running I am guessing? Does it shift all the gears just feels weird to you? Quote
AirForceBanshee Posted July 23, 2014 Author Report Posted July 23, 2014 Just felt weird but working now Sent from my iPhone using Tapatalk Quote
trickedcarbine Posted July 23, 2014 Report Posted July 23, 2014 Same way you expect a chick to stroke ya nuts while she blows ya, the banshee trans is the same. You gotta tweak the shaft while you diddle the shifter. Problem solved. 2 Quote
WINDYCITYJOHN400 Posted July 24, 2014 Report Posted July 24, 2014 You might as well throw that flywheel in the trash now before it causes damage to your crank. If that's a Ricky Stator, you can just throw out the whole set-up. Quote
