aleyesonme Posted July 12, 2014 Report Posted July 12, 2014 Hello members, I've searched but no results to my question....I always have used super techniplate, but the shop I get it from only has original....so I bought it anyway....can I mix what I already have in the tank. ? Found out that the original doesn't have the castor in it...will I be fine or not use...thanks Quote
hp2000 Posted July 12, 2014 Report Posted July 12, 2014 You bought R50 ? Sent from my iPhone using Tapatalk Quote
aleyesonme Posted July 12, 2014 Author Report Posted July 12, 2014 No it's techniplate. ..just original Quote
03DMshee Posted July 12, 2014 Report Posted July 12, 2014 Sounds like you bought the same thing. ...id run it Quote
aleyesonme Posted July 12, 2014 Author Report Posted July 12, 2014 Well it's the same stuff but missing one main ingredient. ...the castor oil...not sure how important that is... Quote
registered user Posted July 13, 2014 Report Posted July 13, 2014 (edited) website says they mix but maybe call klotz to double check. or dump the shit in your tank to the lawnmower or car Edited July 13, 2014 by registered user Quote
aleyesonme Posted July 15, 2014 Author Report Posted July 15, 2014 Ok thanks...I'll give klotz a call...thanks for the info Quote
jbooker82 Posted August 3, 2014 Report Posted August 3, 2014 SuperTechniplate is %80 Original Techniplate 20% Benol Caster Oil. Original Techniplate Is 100% Techniplate. They mix fine. Quote
jbooker82 Posted August 6, 2014 Report Posted August 6, 2014 Mix some benol in and you will have another quart of Super Techniplate. Quote
