Willybanshee Posted July 4, 2014 Report Posted July 4, 2014 Hi! I just rebuilt my banshee and it starts fine but doesnt want to accelerate more than 1/4 throttle. Its like something is limiting it because It bogs in a constant rythm and the engine stays on. I already clean the carbs many times, switched jets, move the needles, changed spark plugs, checked all the intake system for cracks or leaks,cleaned the gas tank and fuel petcock. Compression is 110 at 6500 ft above sea level, im in Colorado Springs. I think its an electrical problem. The thing is that it ran perfect before i opened the top end. Please help for suggestions!! Thanks! Btw sorry for my english... Quote
Surfrjag Posted July 4, 2014 Report Posted July 4, 2014 Tors or parking brake sensor. Disconnect them Quote
Willybanshee Posted July 4, 2014 Author Report Posted July 4, 2014 I know the TORS are unplugged but im gonna check the parking brake! Thanks! Quote
trickedcarbine Posted July 4, 2014 Report Posted July 4, 2014 Carb slides in right? Bowls on correct side? Carb tops seated and sealed? Filter is fresh and clean? Not just looks clean? Quote
Willybanshee Posted July 4, 2014 Author Report Posted July 4, 2014 OMG the bowls! I need to check that! Thanks!!! Quote
tfaith08 Posted July 7, 2014 Report Posted July 7, 2014 Whenever you get it sorted out, try to come back and post the solution. That's what makes forums work. Quote
Willybanshee Posted July 8, 2014 Author Report Posted July 8, 2014 It was the parking brake sensor, thanks guys!! Quote
