danny.jaramillo1 Posted June 23, 2014 Report Posted June 23, 2014 Does anybody know if off the shelf Banshee drag pipes will mount on a HS hill shooter chassis without any modifications? Quote
Deadbeat Posted June 23, 2014 Report Posted June 23, 2014 if you mean out of frame pipes they bolt to the pegs, so youre gonna need something pegswise that will take a bolt in the end Quote
danny.jaramillo1 Posted June 23, 2014 Author Report Posted June 23, 2014 Just wondering if the bend is the same and if I'm going to have to fabricate a bracket for the peg. Quote
10milmike Posted June 23, 2014 Report Posted June 23, 2014 So you finally got a frame? Good! If you want the pipes to fit right take them up to mat's shop and have him fit them to the chassis. Sent from my SCH-I605 using Tapatalk Quote
locogato11283 Posted June 23, 2014 Report Posted June 23, 2014 So you finally got a frame? Good! If you want the pipes to fit right take them up to mat's shop and have him fit them to the chassis. Sent from my SCH-I605 using Tapatalk Just curious, but how does he "fit them to the chassis?" Quote
10milmike Posted June 23, 2014 Report Posted June 23, 2014 Because some chassis have the foot pegs welded on. And they are moved forward or backwards. Mat moves the bracket on the pipe to fit the chassis. Because all his pipes are made to fit stock pegs. Sent from my SCH-I605 using Tapatalk Quote
m671054 Posted June 23, 2014 Report Posted June 23, 2014 Do they need to be modded at the neck to clear the lower rails like lsr chassis need? 1 Quote
shanYE west Posted June 23, 2014 Report Posted June 23, 2014 What you get and what you ask for are 2 different things.. Quote
locogato11283 Posted June 23, 2014 Report Posted June 23, 2014 What you get and what you ask for are 2 different things.. Such a nice guy though!! Quote
camatv Posted June 23, 2014 Report Posted June 23, 2014 i just make a small mount between the pipes and the peg? never thought about having to send pipes in to have the complete mount moved around.. that way if you move pipes around on differnt frames you just have the adapter to fit them on the chassis. then just hope that each set of pipes mount on the pipe is actually in the same spot most times they are not. hell sometimes i have no idear where they are mounting these things too on a so called jig when they are built. Quote
locogato11283 Posted June 23, 2014 Report Posted June 23, 2014 I think blind monkeys weld them up. Jigs are stupid. Quote
10milmike Posted June 23, 2014 Report Posted June 23, 2014 Fuck you pussy!! !!!! Sent from my SCH-I605 using Tapatalk Quote
