  • Replies 35
  • Created
  • Last Reply
Top Posters In This Topic
Guess your right its on the carb not the bowl that there is an added copper tube for the choke. The bowl that goes on the choke side has a small bebe in the area I circled in the pic. It also had a casting number 1-1. e7ujy7e3.jpg
Sent from my SM-N900V using Tapatalk
Ok everybody here's one for you!! I've had it back together for about a day. I live in Ontario and my garage isn't heated. It's been around +1 to +4 give to take. I put a little heater under the Shee for about 24hrs. I went out yesterday morning to try to start it and BAM, fired up first kick!:) has anybody heard of a Shee being that cold blooded that it needs a block heater!! Lmao:) so I've had the heater under it again and gonna go out in a bit and see if it'll start again. I had the garage warmed up the day I was working on it and it didn't start that night. This just seems very weird. Would the low compression have anything to do with this?? Or do I have the cold blooded beast that likes a little heat when she's cold? THANKS all for the help hopfully the weather gets a bit warmer here in Canada and I won't need a heater any more:) let me know if anyone has ever heard of such a thing!!
I'm lost, tried this morning and it wouldn't start, choked it and pinned the throttle and kicked and kicked. Checked the plugs after about 50 kicks and they we're dry as a bone!! What else could be going on? Carb issue or not pulling in the fuel issue??
You need good compression to pull fuel to the cylinders. Basically when your motor is warm the pistons expand and give you the compression you need.
Sent from my HTC One using Tapatalk
sounds like too low of compression mixed with cold weathers making it have problems. try some new rings if everything else is checking out.
