Rapture Posted April 7, 2014 Report Posted April 7, 2014 Anyone every tried spraying their fairings with plastidip? Thinking it might stretch with the plastic as it flexes and not crack... Quote
3wheeledfanatic Posted April 7, 2014 Report Posted April 7, 2014 I did my grill plastics with it..seems to be holding good. I have heard that it peels but have been lucky..could be that my grill does not hit anything. Sent from my H866C using Tapatalk 2 Quote
Glenyboy Posted April 7, 2014 Report Posted April 7, 2014 Ddq did his in it, ask him how it's holding up. You'll have to show him your chest first though. Quote
Young Guns Racing Posted April 7, 2014 Report Posted April 7, 2014 Gotta customers bike here in the shop, he did it 3 months ago - peeling now like skin after a nasty sunburn. Maybe if applied properly it would work but in this instance all its doing for him is peeling. Quote
CrazyBRONCOguy Posted April 7, 2014 Report Posted April 7, 2014 I also have done it and it does seem to be pelling on mine as well. I did it to a new set of fullbores as I could not find black. It only peels where I have hit it though. Also fuel will take it off. I have been getting ready to re-do mine. The ruffer side of my fullbores where the tires throw stuff has been holding up great, it has not peeled off there. I think if you scuffed the plastic before you put it on you would be good. I have it on some of my truck and it has held up fine where I prepped it. Quote
hoppedupandcutdown Posted April 8, 2014 Report Posted April 8, 2014 How much Plastidip did it take to do the Fullbores inside and out? And how many coats? Quote
Glenyboy Posted April 8, 2014 Report Posted April 8, 2014 I've read the more coats the better, as when it's thicker it's easier to peel off when you've had enough of it. They advise 5-7 if you use the thinned down stuff. Not sure about the can. Quote
CrazyBRONCOguy Posted April 8, 2014 Report Posted April 8, 2014 Agree with the above exactly. I have three to four cans on my plastic. 1 Whole can on the bottom of the rear fenders, I went lighter on stuff around tank on inside. I also would say more coats the better, the youtube videos of it coming off in a sheet most likely have around 6-10 coats at least anything less then that and it wont do it. https://www.dipyourcar.com/home.php this website has a lot of good info on how to do it correctly, also they sell every color you can get the stuff in. Quote
hoppedupandcutdown Posted April 8, 2014 Report Posted April 8, 2014 I assume you mean spray cans? Quote
Glenyboy Posted April 8, 2014 Report Posted April 8, 2014 Dip your car is not spray cans, it's thinned down to go through a sprayer. Quote
Glenyboy Posted April 8, 2014 Report Posted April 8, 2014 They have a forum on there, you may be best to ask questions there. Quote
CrazyBRONCOguy Posted April 8, 2014 Report Posted April 8, 2014 when I said 3-4 I meant the spray cans... That website does also sell the spray cans but they do have it thinned also Quote
Banshee Chad Posted April 9, 2014 Report Posted April 9, 2014 (edited) I've used it on truck grill, center caps, wheels. Works great on some stuff. Covered interior chrome trim as well, shit was blinding when sun hit it. Anything that gets wear it won't do well, I did a phone case.. And half a day of in and out of pocket it was worn off. But had on grill for 1 yr, peeled outter ring off easily and looks good under. Did 7 light coats. Also did mirror on truck, one broke and dealer replaced, peeled off the other one to match. It got wear lines from when it was folded in. Holds up to bugs and pressure washer good tho. Gas and brake kleen take it off like a champ too if u got it on too thin to peel. Edited April 9, 2014 by Banshee Chad Quote
