I just went riding and  hit a whoop really hard. The bike then started to bog on the right cylinder everytime I hit some bumps after that. It will pull clean on flat ground, but when I hit some whoops, the right cylinder wants to cut out. I run stock carbs with a twist throttle. I have never had this problem before. I checked the plug wires, and they were snapped on. Any ideas?
what level should the floats be at?
20mm-22mm
Check for the brass washer under the main jet that hold the " emulsion?" Tube in place, with out them the tube can slide up into the carb throat and cause a bog
