dburnexx Posted February 17, 2014 Report Posted February 17, 2014 I seem to have a problem hitting what feels like neutral between 2nd and 3rd happens occasionally in drags and some times it does the same goin through trails. What can i do to fix this issue Sent from my GT-S5360L using Tapatalk 2 Quote
uman1030 Posted February 17, 2014 Report Posted February 17, 2014 adjust your ecentric bolt correctly. when mine wasn't adjusted correctly it would hang in between gears Quote
dburnexx Posted February 17, 2014 Author Report Posted February 17, 2014 Where is it located,how do i adjust it properly Sent from my GT-S5360L using Tapatalk 2 Quote
sheerider11 Posted February 17, 2014 Report Posted February 17, 2014 Pull trans Send to redline Get pro mod Get new eccentric, locking tab, shift shaft, shift pro Install Thank me later Or check your eccentric and shift shaft. Quote
dburnexx Posted February 17, 2014 Author Report Posted February 17, 2014 What is the pro mod it might already be done by the owner before me he was talkin about a mod he had done to the transmission Sent from my GT-S5360L using Tapatalk 2 Quote
uman1030 Posted February 17, 2014 Report Posted February 17, 2014 What is the pro mod it might already be done by the owner before me he was talkin about a mod he had done to the transmission Sent from my GT-S5360L using Tapatalk 2 promod is when they cut your trans to make it shift easier while still allowing for normal operation and no damage from backloading it. Over ride transmissions which are more geared toward racing you can NOT backload or it can cause damage and bend the shift forks. If you had an override and you were backloading it the shift forks may be bent and that could be whats causing your issue. did your trans shift from nuetral and down or did it have the normal neutral inbetween 1st and 2nd? how many gears did it have? Quote
dburnexx Posted February 17, 2014 Author Report Posted February 17, 2014 I have six gears and i have a normal neutral between 1st and 2nd. I think thats what he had done. He said it has the shift star mod done Sent from my GT-S5360L using Tapatalk 2 Quote
uman1030 Posted February 17, 2014 Report Posted February 17, 2014 shift star is a very basic mod they just grind off some of the star points to make it a little easier to shift. That is not exactly a promod tranny but usually part of it Quote
dburnexx Posted February 17, 2014 Author Report Posted February 17, 2014 Ok and i realized what bolt is the eccentric now. dont you have to pull the clutch basket to get to it Sent from my GT-S5360L using Tapatalk 2 Quote
uman1030 Posted February 17, 2014 Report Posted February 17, 2014 yes, you would need to remove your basket. when i did mine i couldn't get it to adjust well because the spring on the shift shaft that makes contact with the eccentric screw had grooves worn on either side in it so i bought a good condition used shift shaft assembly. also you adjust it while in gear not in neutral. Quote
trickedcarbine Posted February 18, 2014 Report Posted February 18, 2014 Pull trans Send to redline Get pro mod Get new eccentric, locking tab, shift shaft, shift pro Install Thank me later Or check your eccentric and shift shaft. ^ thisAlso add the modded shift shaft from fast. Quote
