Pastrykiller Posted February 12, 2014 Report Posted February 12, 2014 (edited) Do you have the domes for it? If so, measure them and let us know Edited February 12, 2014 by Pastrykiller Quote
Pastrykiller Posted February 12, 2014 Report Posted February 12, 2014 On the other hand, I have a nice 421 cub with domes and extenders. Will even include pistons. Hit me up if you wanna stop wrecking your brain. Quote
BANSHEEBEEFM2M Posted February 12, 2014 Author Report Posted February 12, 2014 Pastry killer how much? Sent from my N8000_WHTE_CKT using Tapatalk Quote
Pastrykiller Posted February 12, 2014 Report Posted February 12, 2014 Pastry killer how much? Sent from my N8000_WHTE_CKT using Tapatalk Hit me up in the pm with your cell number Quote
trickedcarbine Posted February 12, 2014 Report Posted February 12, 2014 You more then likely have a stock stroke with the 65 mm bore. Quote
BANSHEEBEEFM2M Posted February 12, 2014 Author Report Posted February 12, 2014 But the bore measures out at 64.4something Sent from my N8000_WHTE_CKT using Tapatalk Quote
Deadbeat Posted February 12, 2014 Report Posted February 12, 2014 64.9..64.4...i think you might have adjustable bores Quote
BANSHEEBEEFM2M Posted February 12, 2014 Author Report Posted February 12, 2014 Lmao I was wrong its 64.4 Sent from my N8000_WHTE_CKT using Tapatalk 1 Quote
fappy'97 Posted February 12, 2014 Report Posted February 12, 2014 64.9..64.4...i think you might have adjustable bores Adjustable bores. This is a great idea! Quote
trickedcarbine Posted February 12, 2014 Report Posted February 12, 2014 Ok. Pretty sure the only 64 bore cubs were stock stroke. So that is for 64mm piston the exess is just the clearance Quote
camatv Posted February 13, 2014 Report Posted February 13, 2014 oh good gravy!!! there are 2 numbers CAST in the intake. what are they!! i can see them in the pic but cannot read them. they are on the INSIDE of the reed area that says what the bore and STROKE the cylinder was setup for.. NOW that said its not to say that at some time it was originally blowed sky high. replated and resetup by milleinum, or even reported different setup by someone else. no way of knowing except to measure the cyl height, measure the port layout, and then go from there... 1 Quote
Wildcardracing Posted February 13, 2014 Report Posted February 13, 2014 The stroke is cast into the inside of the intake if it's a 4mil it will say 58 Quote
BANSHEEBEEFM2M Posted February 13, 2014 Author Report Posted February 13, 2014 It says 54 Sent from my N8000_WHTE_CKT using Tapatalk Quote
trickedcarbine Posted February 13, 2014 Report Posted February 13, 2014 (edited) 350 class motor. Gonna be fun if you guys hillbilly it together even half as good as it should be. Edited February 13, 2014 by trickedcarbine Quote
Pastrykiller Posted February 13, 2014 Report Posted February 13, 2014 My lil 358 cub laid down pretty good numbers on pump gas and as cast. Quote
