Larry's Shee Posted February 11, 2014 Report Posted February 11, 2014 Change your top and bottom swing arm bearings WTF do you mean by top and bottom bearings ?????????????????????????????? Quote
gusto Posted February 11, 2014 Report Posted February 11, 2014 Top bearings where swing arm attach to the frame, bottom where axle runs through. Quote
trickedcarbine Posted February 11, 2014 Report Posted February 11, 2014 Ah, pivot and carrier. 1 Quote
Larry's Shee Posted February 11, 2014 Report Posted February 11, 2014 Take your time dont rush and dont get discouraged another tip , dont do one jug then try n match other I use the same toll as long as I can on both jugs . Like ill both intakes at same time same tool then switch tool and do both intakes with that it saves time and keeps everything on plain with each other Top bearings where swing arm attach to the frame, bottom where axle runs through. Ah, I see. When viewed in the wheelie posistion. So that would make it front and rear A-arms, got it. Try Googling top and bottom swing arm bearings. Standard teminoligy is everything OP. Quote
