Do the side covers have to be off in order to leak check? Wouldn't I know I had a leak in the bottom end if I sprayed hot soapy water around the top end, and it didn't bubble? This is my first build so I'm new to this.
 But at first the boost bottle was leaking bad
There you go. Now aren't you glad you did a leakdown test before you burned down the motor? Now get rid of the boost bottle before you crack the intakes and burn down the motor.
See I toe jew.
Leakdown test FTMFW!
Now you can go burn it down for the #2 most common reason...........jetted wrong. LOL
