If you're bending it, somethings wrong. It should rotate easy. If you want to make a really nice tool, find a decent quality phillips screwdriver that has the same size shaft and grind the phillips end off it.
craftsman #3 should be the same size
just cut the Philips end off and BAM you have a nicer better tool
No it spins but some times its tight in certain areas and it seems to bend easy. I think I screwed the tool up when I first used it. A combo of new powder coating and nuts not loose enough caused me to bend it. I bend it back but it think its just weaker now. It moves a inch or so easy in both directions then gets tough. Probably dirt.
 bend a Phillips
^^^^These
Or have you tried a philips screwdriver? Works great for me.
<p>1/4" drive extension cut off. No bendy!</p>
X2 that is what I have always used
^^^ Chariot Chain tensioner......till the chain snaps and whacks the cases.
