ETR174 Posted January 3, 2014 Report Posted January 3, 2014 So if I'm forgetting something correct me but I heard that these compression tests are very simple tests that tell your best gas/oil ratio for your engine and carb set up? If this is true can I do it myself? If so what are the qualifications? If not so then would a power sports dealer be able to do this? Sent from my LG-LS970 using Tapatalk Quote
#1JUANstunna Posted January 3, 2014 Report Posted January 3, 2014 Get a gauge, remove spark plugs, attach said gauge, hold throttle wide open, kick engine over until the needle stops moving. Report back and someone will help you from there. Quote
hoppedupandcutdown Posted January 3, 2014 Report Posted January 3, 2014 Also do a leak down test http://bansheehq.com/forums/index.php?showtopic=110585 Quote
jbooker82 Posted January 3, 2014 Report Posted January 3, 2014 Get a gauge that has the correct thread lenght and has the shrader valve in the verry tip. Any volume added before the shrader valve will be added volume to the combustion chamber. Quote
ETR174 Posted January 3, 2014 Author Report Posted January 3, 2014 Get a gauge, remove spark plugs, attach said gauge, hold throttle wide open, kick engine over until the needle stops moving. Report back and someone will help you from there. Alright thanks. Do I need gauges for both cylinders? Also do a leak down test http://bansheehq.com/forums/index.php?showtopic=110585 I am experiencing lack of air but that's because it currently has the stock filter pumped with air filter oil. Get a gauge that has the correct thread lenght and has the shrader valve in the verry tip. Any volume added before the shrader valve will be added volume to the combustion chamber. So it screws into the cylinder heads where the spark plugs should be? Ohhhhhhhh I get it now. Alright do I need to count the kicks or something? This may sound stupid but the engine won't start because it obviously doesn't have any spark correct? Sent from my LG-LS970 using Tapatalk Quote
#1JUANstunna Posted January 3, 2014 Report Posted January 3, 2014 Alright thanks. Do I need gauges for both cylinders? I am experiencing lack of air but that's because it currently has the stock filter pumped with air filter oil. So it screws into the cylinder heads where the spark plugs should be? Ohhhhhhhh I get it now. Alright do I need to count the kicks or something? This may sound stupid but the engine won't start because it obviously doesn't have any spark correct? Sent from my LG-LS970 using Tapatalk One gauge but you need to check both cylinders and no it won't spark as long as you pull the other plug wire off. Quote
ETR174 Posted January 3, 2014 Author Report Posted January 3, 2014 Do I have to keep the other plug in or can I take it out? Do I need to pay attention to anything either like how many kicks it takes until the gauge needle stops moving? Sent from my LG-LS970 using Tapatalk Quote
5150banshee Posted January 3, 2014 Report Posted January 3, 2014 Both plugs out Compression tester in one side Ignition off Throttle wide open 10 good kicks GOOD LUCK!!! Sent using Iphone5 onTapatalk Quote
hoppedupandcutdown Posted January 3, 2014 Report Posted January 3, 2014 Get a gauge, remove spark plugs, attach said gauge, hold throttle wide open, kick engine over until the needle stops moving. Report back and someone will help you from there. You were actually right the first time, a better reading this way Quote
ETR174 Posted January 3, 2014 Author Report Posted January 3, 2014 Both plugs out Compression tester in one side Ignition off Throttle wide open 10 good kicks GOOD LUCK!!! Sent using Iphone5 onTapatalk You were actually right the first time, a better reading this way Ok thanks for clearing that up guys. I guess I could always turn the ignition off too . All that needs to happen is the cylinders need to compress from the kicks in order to build up pressure right? Sent from my LG-LS970 using Tapatalk Quote
#1JUANstunna Posted January 3, 2014 Report Posted January 3, 2014 Put your plugs back in the plug boots and hold the spark plugs by the threads and kick it over too or get a buddy to hold one and you hold the other while holding the throttle open. 1 Quote
ETR174 Posted January 3, 2014 Author Report Posted January 3, 2014 Compression test does not tell you the best gas/oil ratio. It does not tell you the best carb set up. It simply tells you the cranking compression of the engine. So like what jets to use? Sent from my LG-LS970 using Tapatalk Quote
sheerider11 Posted January 3, 2014 Report Posted January 3, 2014 Nope. Just static compression. Gives you an idea of what fuel to go with. And let's you know what kind of shape the top end is in. You can find a 20psi diff in the cylinders, low compression. Quote
Nieskes Posted January 3, 2014 Report Posted January 3, 2014 Put your plugs back in the plug boots and hold the spark plugs by the threads and kick it over too or get a buddy to hold one and you hold the other while holding the throttle open.this is how I always do it. Quote
