You've got different backspaces wheels on the front of that thing. Alot more brake caliper sticking out onnthe right. Wheel bent or something too?
Just ride it till it melts down. Then sell it. Won't matter if the cambers off a bit sitting in the garage with the motor in a molten mess. :)
The spindle is what actually look bent from looking at it closer , I'm going to change that out and see.
And I can only paste links on the phone also . Sucks
How did you post the link? This junk forum wont let me post links in the reply unless im using my phone
Use photobucket  :ph34r:
If you use photo bucket you still have to copy and paste the IMG code from the pic which is what we can't do on the desktop, on this forum only, I'm apart of many other forums where I use photobucket and the IMG code pasted into the post and it works fine. On this forum I could only paste via phone.
