Connect the two nipples protruding on both carbs level with the choke tube on the inside between them. And starter up bud
Sent from my Galaxy Nexus using Tapatalk
Must a ran like shit when it ran. Thats a horrible vacume leak even if u manage to start it.
so that's most likely my problem. and im assuming it doesn't affect rollstarting or while driving?
No it was running like shit every time you rode it. No question about it.
Edit I want to quantify this statement. This was under the impression that the choke tube wasn't and had not been connected.
nope sorry still not fixed it seemed the hose got snagged off some point earlier today it was on the floor of my garage and I put it on. still no change in the starting sounds exactly the same.
Sigh... When you pull a plug is it wet with gas? Also hold the tip of the plug to the head making sure it has a good contact to groung it. Doese it have bright blue spark
yes it was wet with gas but i checked it right after like 20 kicks. and i couldn't get a spark at all to come up at all. what does that mean, stator?
well i picked some up but didn't think to look at them and it turns out they gave me warrior 350 plugs. so no new plugs, ill change them out tomorrow and see if i get spark. but if i don't what could be the problem
ok when i get done with school tomorrow ill pick up some new plugs and ill check spark and let you guys know but im going to bed for tonight.
