ok guys pretty new to modding the banshee but plenty of experience rebuilding motors ect
banshees only motor mods currently are
T5 pipes
Uni filter
going to upgrading a bunch of stuff and want to do everything together, getting the 370cc cub cyls off 2strokelove
have just ordered
VF4 reeds
pro designs cool head/21cc domes
timing plate
looking at
carb kit
33mm Keihin PWK Carbs
billet intakes
KnN filters straight on the carbs
throttle cable
so things im not so sure about is what else I need to do or should do at the same time
apart from true/welding the crank what other must have items are there or should I take care of or is that basically it
bike is for dunes/trails on pump fuel
thanks for any help
thanks
Wow just blow thru your life savings there? Lol sounds like quite the dune/trail bike once said and done. All that power is gonna be a handfull on the trails with out some suspension upgrades.
ha ha yeah it hasn't been a cheap experience so far but that's all part of the fun
I already have wider axle and those alba lt a arms just havnt bought shocks just yet
hopefully this give me everything im after from the bike
Mod the trans
Mod the shift shaft
Mod the shift star
Billet basket
Pancake bearing
Billet impeller
Advance timing
Of coarse all new seals
Leakdown test
x2 all things I did when i built my stock cylinder 4 mil. Its already been mentioned but if you do not do something with that suspension, your new found power will almost be "useless". Stock suspension wont help you get it all to the ground. You've got more money to spend lol you will be 34973247x happier after you do tho
Don't worry new shocks will be on the way before this motor is all together
So will there be any gains from changing carbs ? Or none that are worth the price tag of them
Gong from stock carbs to 33s on a ported cub would definetly be worth it. I don't have any numbers to puke out, but a ported cub is going to flow WAY more than a set if stock cylinders. Bigger carbs would be beneficial.
  • 3 weeks later...
More air in the right setup is more hp. Simple as that. I love pwks, they respond really well and are super easy to jet and tune. I run 35 pwks on my stock cyld 4 mil, its just my prefference but I will never run a stock carb again if I can help it lol
And if you havnt cosidered it toss those off the shelf domes up for sale and have a builder cut you some custom domes. You'll get a little more out of it than u will with standards
