98 banshee left cylider miss @ idle and oil shooting out exhaust
hi I have a 98 banshee runs like crap left cylinder misfires @ idle and shoots oil out the exhaust. only time it runs descent is during high revs. I checked compression and its a little low (100psi) in both cylinders. I have just put a twist throttle on and idle kit, I swapped plug wires and no change in miss. cleaned carbs and jets replaced plugs. does anyone have any ideas?
  • 3 weeks later...
  • 1 month later...
  • 4 weeks later...
Is the oil out the exhaust transmission fluid?
Miss is on left side not right. Check main jet maybe its loose in the bowl, that would cause your problem. And sound like the top end needs freshend up compression is low.
  • 2 weeks later...
