tdod101 Posted November 4, 2013 Report Posted November 4, 2013 Probably won't winterized this year so I can go out on the ice, but I'm assuming I should change my main jets , maybe 1 or two sizes up ? Quote
Larry's Shee Posted November 4, 2013 Report Posted November 4, 2013 Look at the Mikuni pocket tuner shows 1 size for every 20* drop in temps. Better safe than sorry. Might check with others as to possibility of over cooling and cold seizing. Quote
ginger Posted November 4, 2013 Report Posted November 4, 2013 you can cheat it sometimes if you run a air box and no lid, put the lid on and it can make up for it Quote
trickedcarbine Posted November 5, 2013 Report Posted November 5, 2013 Look at the Mikuni pocket tuner shows 1 size for every 20* drop in temps. Better safe than sorry. Might check with others as to possibility of over cooling and cold seizing.Wouldn't imagine you can over cool.... But as far as the cold seizure, yeah lotta two stroke guys get them in the cold. Prevent it with a thorough warm up procedure and good jetting. Quote
Nieskes Posted November 5, 2013 Report Posted November 5, 2013 Sounds ghetto, But I always took a thin piece of cardboard and covered half my rad or more up every winter. Helped alot! Quote
tdod101 Posted November 5, 2013 Author Report Posted November 5, 2013 True dat, I do it with my truck too. Okay thanks guys! Quote
wycked68 Posted November 6, 2013 Report Posted November 6, 2013 better to waste plugs than jugs! Quote
Pasi S. Posted November 9, 2013 Report Posted November 9, 2013 My advice is - listen your motor. I have been anything between 158 to 175 in winter. Quote
Banshee Chad Posted November 11, 2013 Report Posted November 11, 2013 you can cheat it sometimes if you run a air box and no lid, put the lid on and it can make up for it That's what I do. Quote
