its more likely that it went into the pipe than to the cases. unless your pipe was filled up and your radiator was completely empty. i wouldnt worry about it. maybe just kick it over a couple times with the plug removed and then run it.
the fluid that is on the piston did not come from the leak you have.  That wound up on the piston from pulling the head.....it just what happens when you want to check the pistons.  There really isn't a way to get to the crank case without cracking it open.
