ModQuad was a ProDesign knock off with a softer water pump shaft. So the seal would wear in to the shaft and leak coolant in to the transmission. I would pass on them. If you want a real water pump I would get the Mull Engineering pump. It is a total redesign. Mull also makes a billet water pump gear as well.
Edited by jbooker82
^^^ What he said.
Thanks for the greeat info. I looked into the Mull one and they are on back order, so I got a pro desighn. Funny they had it listed for $58 for the RZ350, and same seller had it listed for $70 for Banshee.
