Has anyone used or heard anything about using water wetter and distilled water to replace your antifreeze? I run this in my street bike and have noticed a difference, it don't get as hot as quick as if you run antifreeze. Or even run the water wetter in your antifreeze? Wanted to see if there is a noticeable difference or not.
Thanks guys.
Guest JohnTabata
I use distilled water and Redline WaterWetter for its cooling and corrosion protection. I'm also not in freezing conditions.
LOL....any facts to support that claim?
Yes I have tried it down here in Miami. A bigger Radiator with a better water pump with antifreeze. And my temperature was going a little high. When I switched to engine ice. My temperatures maintained a little lower then with regular antifreeze. All of this high temperatures takes place when cruising at low speeds. It made a big difference in my setup.
Sent from my HTC One using Tapatalk 4
I did some research and ppl complained about a black sludge that water wetter left behind. But this was with a 50/50 mix of coolant and water. I think running distilled water and the water wetter would be better. They also have a diesel version of water wetter that doesn't have the silicates in it.
50/50 is wayyyy too much antifreeze,,,  i usually do around 25% antifreeze, 50% distilled water, and 25% water wetter, and yes, it gets far below freezing in the winter time
Edited by Colby
