ericdoedoe Posted July 29, 2013 Report Posted July 29, 2013 im going from stock 26mm to 35mm, when i buy them, what do i have to do as far as jetting goes, do i have to buy bigger jets or use the same size as the old ones ? Quote
joey83 Posted July 29, 2013 Report Posted July 29, 2013 Look through the jetting section and read what others have used. They won't be the same size as your stock carb jets..... Quote
Starwriter Posted July 29, 2013 Report Posted July 29, 2013 not many mods, i got sst gold series fmf pipes, hp clutch, and thats about it, im going from stock 26mm to 35mm, WOW! Quote
J-Madd Posted July 30, 2013 Report Posted July 30, 2013 Stick with the stock carbs. No reason to run anything bigger on your motor. That's what he means. Quote
Deadbeat Posted July 30, 2013 Report Posted July 30, 2013 waste of money on a stock motor, put your money into an adjustable timing plate if you want to wake the bike up Quote
87sheerips Posted July 30, 2013 Report Posted July 30, 2013 I have a dune port 350 with 35 PWK. It runs great. Came from 28 PWK. Gained top end, didn't lose much bottom end. I am running 152 mains with a 48 pilot. Try that, should put you close or a little on the lean side. Quote
possum Posted July 30, 2013 Report Posted July 30, 2013 I have a dune port 350 with 35 PWK. It runs great. Came from 28 PWK. Gained top end, didn't lose much bottom end. I am running 152 mains with a 48 pilot. Try that, should put you close or a little on the lean side. Jd dont come in here with facts. Theres no place for that here. (sarcasm) 1 Quote
87sheerips Posted July 31, 2013 Report Posted July 31, 2013 But OP has a stock port motor. Yea, nothing more that 28PWK then. Stock carbs I'm sure will work but I have never ran them. Quote
