key way for 40mm drag axle
Factory350
As I recall the mod quad uses a true 3/8 key stock and the jj&a is machined down a touch and the wheel hub keys have machined marks on them so you can easily adjust you hub spacing equally.<br /><br />Now with that said. I have an EARLY JJ&A and it does use the full size key ways. But its OLD, like one if the first ones old. Im not sure when they made the switch but Id be amazed if your axle does not have the cut keys on it.<br />
