I recently bought a 04 banshee twin 350. It will start right up with little problems, however, if I do not keep reving the motor it will die instantly. I have cleaned both carbs and readjusted the floats from a prior leak that was no problem fixing. Next is the problem with it bogging as I accelerate at a high speed. It has a lag in the throttle as well as cutting out. I do not have a housing for the air filters but I have yet to drive it through water or on a dirt track. Any help would be greatly appreciated!!
jetting off? What mods are done to the bike and what jets are in the carbs?
Do a leakdown test yet? Wonder if there is a air leak in your motor and its slightly leaning you out.
Keep to one thread? You started another thread already.
How many turns out are your fuel air screws?
And if you feel its necessary to start 2 threads at least spell idle correctly the second time.
Hahaha agreed. Its not even a hard word!
