Not currently running one but I can tell you that streamlIne has a lot of issues with the master on their kits. I have heard nothing but praise from people with a Magura set up with the braided line.
Had a streamline when they first came out for $300, didn't last long. Not sure I'd try one again knowing that my current clutch set up is damn near bullet proof and quite easy to pull.
Junk. Keep a cable clutch.
^^ This.
  Also, get an ASV lever and new cable. Lube the cable before installing (i like the "Gunk" brand chain and cable lube with Teflon).
Simple,effective , easy pull.
I have, sitting in the box my asv lever came in, a streamline hydro clutch.
Things are fucking garbage cans. They are a real treat to bleed if you ever have had the pleasure of doing that.
Also, to be honest, with a FAST HD clutch, asv f3 pro lever and a new lubed cable, it feels better than the streamline ever did.
