385banshee Posted May 28, 2013 Report Posted May 28, 2013 So i bought a 2004 banshee. And i was wondering if there was a way to figure rough hp numbers, as i have no access to a dyno locally. And im just curious. Im running a 385 kit(65mm pistons and 4mil crank), 19cc domes, im at 175psi compression, pro circuit platinum pipes and silencers, i think its an mx/trail port, stock carbs, unknown brand cdi, and +4 or 5 timing advance, and a noss performance cool head. I know hp isnt everything, but im curious to know what its around if anyone knows how to get rough numbers. Sent from my SCH-I535 using Xparent Skyblue Tapatalk 2 Quote
dirtydownunder Posted May 28, 2013 Report Posted May 28, 2013 Just make up a number in ya head and run with it. 1 Quote
fappy'97 Posted May 28, 2013 Report Posted May 28, 2013 Find a crap ton of horses, and start out with 50 of them. Keep adding one horse until your quad won't pull them. The number of horses you pull is how much HP you've got. 1 Quote
Coupelx Posted May 28, 2013 Report Posted May 28, 2013 Just pic a number that makes your dick look bigger and impresses your friends. Quote
special06shee Posted May 28, 2013 Report Posted May 28, 2013 I had a 385 dune/play port, 155psi, t5's,+4timing, pwk35's. it dynod 71.5hp Quote
trickedcarbine Posted May 28, 2013 Report Posted May 28, 2013 If done right you should be about 60-65 HP Quote
