89mustang Posted May 14, 2013 Report Posted May 14, 2013 Hello new to the website. I just purchased a 2000 and it's bone stock. When I first got it the previous owner had done a top end and just about all the hose clamps were loose! I checked all the clamps and tightened them. Tonight took it for a ride and was getting on it pretty good when I got home and shut it off it started puking coolant out and sounded like it was sucking air. I did a search couldn't find anything. Any help would be greatly appreciated. Quote
possum Posted May 14, 2013 Report Posted May 14, 2013 Check your cap. The seal gets brittle and cracks and dosent seal. Quote
89mustang Posted May 14, 2013 Author Report Posted May 14, 2013 Thank you. Will check it when I get out of work Quote
Starwriter Posted May 14, 2013 Report Posted May 14, 2013 Could also be a chewed up water pump gear or impeller. 1 Quote
89mustang Posted May 14, 2013 Author Report Posted May 14, 2013 Is there another place to order a radiator cap besides the dealership? They want $36 for an oem. Neighbor has a banshee going to grab his cap and try that first Quote
89mustang Posted May 14, 2013 Author Report Posted May 14, 2013 Is there a way to check the water pump gear or impeller? Quote
BUILDER Posted May 14, 2013 Report Posted May 14, 2013 Only way to check the impeller is to pull the cover and look at it. Quote
Starwriter Posted May 14, 2013 Report Posted May 14, 2013 There are a couple ways to test if it's doing something or nothing. Pull the radiator cover plastic off. Make sure the radiator is full. Start the bike up from cold and rev it up a bit. After about 2 or 3 minutes, put your hand on the radiator and feel if it's getting warm. If it's cold, put your hand on the head. If the head is hot and the radiator is cold, the water pump isn't pumping. Another way that has been mentioned here is to start it up and pull 1 of the cylinder drain bolts, rev it and see if coolant shoots out 3 feet. I've never tried that though. Quote
toytech Posted May 14, 2013 Report Posted May 14, 2013 Could also be a chewed up water pump gear or impeller. check at autozone, the lower pressure, caps of from toyota's will work. take it in and match it up. Quote
89mustang Posted May 15, 2013 Author Report Posted May 15, 2013 I ran it today and and both the cylinder head and radiator both were warm to the touch idling. Couldnt get the radiator cap today Quote
trickedcarbine Posted May 15, 2013 Report Posted May 15, 2013 Could also be a head gasket leak. Do a leak down or use a compression gauge that shows pressure loss . 1 Quote
89mustang Posted May 15, 2013 Author Report Posted May 15, 2013 I checked the oil in the case it's not milky. I have a brand new compression tester. Would pressure testing the coolant system be a better to check 1 Quote
noonansar Posted May 19, 2013 Report Posted May 19, 2013 The case oil is for the transmission only, it is seperated and sealed off from the combustion chamber/cylinder/crank area. So a leaking head gasket wouldnt show in the case oil. 1 Quote
dozer Posted May 19, 2013 Report Posted May 19, 2013 But a leaking o ring will allow water in the trans oil. Quote
