So in the process of applying more power to my bike via porting, I decided that I would have my cylinders honed to deglaze them. After putting the top end back together and kicking it over it creates a clattering noise. Like the piston is moving back and forth in the cylinder. The bike had a noise similar to this but now it's considerably louder. Any tips would be much appreciated.
At least you didn't try and pull start it. Seems to be a trend lately.
Yeah I figured it out. When he honed the cylinders he took them out a bit too far. The cylinders literally just meet the max wear limit. That said we've decided to rebore it and get new pistons $$$. So any recommendations on a .75 over piston.
Pull start like a lawn mower or pull start like towing it and dropping the clutch
Not sure if they make them for banshees but I've had good luck with SPI T-Molly series pistons. Put them in my sled bored .010 over. Very pleased
Are you going from a 64 mm bore(stock) to a 64.75?  You really want to go as small as possible and save cylinders for future bores. Maybe your cylinders need this much to clean up. IDK.
Wiseco has 64.0mm, 64.25mm, 64.50mm,64.75mm, 65.00mm and so on
lol!!!!!!
Rope around the flywheel works every time haha
  • 1 month later...
Hey fellas just giving an update. Managed to get a newish set of cylinders and a head then bored it to 65. Was running great in dunes then a sudden sputter and it quit. I'd put up a photo but I don't know how basically my right piston has a pretty serious hole in it now. So 700$ for three tanks worth of running is pretty good right?..right??
