bansheechrome2010 Posted April 25, 2013 Report Posted April 25, 2013 My banshee started shooting coolant out of the overflow from the radiator when she gets hot and when i turn it off i coild hear coolant boiling.. Need some advice of what could be cause this. Thanks guys.. Btw im new here, its an 03 limited edition with a good bit of work Quote
tdod101 Posted April 25, 2013 Report Posted April 25, 2013 Try not riding it so hard lol. Well for starters, what kind of coolant are you using? Stock or aftermarket rad? Are all the heat fins intact and not bent ? Is your jetting correct ? Quote
hoppedupandcutdown Posted April 25, 2013 Report Posted April 25, 2013 I'd bet it's the water pump impeller, replace the gear and seal while you're in there. Welcome to the HQ ! Quote
JUSTWANNARACE Posted April 25, 2013 Report Posted April 25, 2013 If its a stock head then might be a blow'n head gasket. If its a cool head it may have pushed an oring.. just something to check Quote
trickedcarbine Posted April 25, 2013 Report Posted April 25, 2013 What kind of work is done to it? Did you change anything in the carbs to compensate? Quote
J-Madd Posted April 25, 2013 Report Posted April 25, 2013 Pull the plugs and look for water on them. Quote
VoOK Posted April 25, 2013 Report Posted April 25, 2013 If its a stock head then might be a blow'n head gasket. If its a cool head it may have pushed an oring.. just something to check This happened to me.......head gasket. Quote
bansheechrome2010 Posted April 25, 2013 Author Report Posted April 25, 2013 Its bored 100 over with athena aftermarket cylinders, stock rad fins are all intacts, jetting is fine but has aftermarket carbs.. V force 3 reeds and vito's fat bastard pipes... Quote
Dick Dragon Posted April 25, 2013 Report Posted April 25, 2013 Check for water in cylinders, trans oil and check water pump impeller. Just a start........ Quote
