My banshee started shooting coolant out of the overflow from the radiator when she gets hot and when i turn it off i coild hear coolant boiling.. Need some advice of what could be cause this. Thanks guys.. Btw im new here, its an 03 limited edition with a good bit of work
Try not riding it so hard lol. Well for starters, what kind of coolant are you using? Stock or aftermarket rad? Are all the heat fins intact and not bent ? Is your jetting correct ?
If its a stock head then might be a blow'n head gasket. If its a cool head it may have pushed an oring.. just something to check
This happened to me.......head gasket.
Check for water in cylinders, trans oil and check water pump impeller.
Just a start........
