Banshee SE Posted April 10, 2013 Author Report Posted April 10, 2013 Happened to me, I used a vise grip and unscrewed it like that I already tried with a vise grip and no way?! Quote
Banshee SE Posted April 10, 2013 Author Report Posted April 10, 2013 Just try to grind them flush, centerpunch and get a decent drill bit. I think this will be my next step Quote
nihilism Posted April 10, 2013 Report Posted April 10, 2013 http://blog.eastwood.com/eastwood-chatter/10-tricks-to-remove-stripped-stuck-bolts/ Pretty much sums up most of the technique's. #6 works really well but idk if it would be possible to get a good enough ground to weld on whats left of the studs. Quote
Banshee SE Posted April 10, 2013 Author Report Posted April 10, 2013 http://blog.eastwood.com/eastwood-chatter/10-tricks-to-remove-stripped-stuck-bolts/ Pretty much sums up most of the technique's. #6 works really well but idk if it would be possible to get a good enough ground to weld on whats left of the studs. #6 this is exactly what I let my buddy do. thanks! Quote
Banshee SE Posted April 10, 2013 Author Report Posted April 10, 2013 i was looking for them online and no luck. If my buddy can't remove them I think they will look great in my trash can. i'm gonna take a 20 pounds hammer and I'll destroy them. This is my major reason that I have not buy a new set of Hipers Quote
sheerider11 Posted April 11, 2013 Report Posted April 11, 2013 Ill buy them from you. I'll pay more then him Quote
vulvafan537240 Posted April 11, 2013 Report Posted April 11, 2013 Ill come pick them up. I'm closer than the other 2 numb nuts. Quote
nihilism Posted April 11, 2013 Report Posted April 11, 2013 #6 this is exactly what I let my buddy do. thanks! No Problem, hope it works out for you. Quote
Banshee SE Posted April 11, 2013 Author Report Posted April 11, 2013 ok guy ebay style, what the best offer?? they already packaged to be shipped to PR but i can cancel it!!! really I don't know what they can worth, the only thing that I know I'm screw with them. It was a bad deal banghead Quote
Banshee SE Posted April 11, 2013 Author Report Posted April 11, 2013 Yes, they are dual 9". Thanks for the interest guys but I'll see if my buddy can work with them before anything. Sheerider11 you are second in line if I decide to sell them another member made me a better offer. Quote
trickedcarbine Posted April 13, 2013 Report Posted April 13, 2013 Grind the tip flat. Hit it with a center punch. Drill down the center. Slam an easy out in to it with a BFH. Twist it out. Quote
