need some help guys..just a few things about my banshee t5 pipes fresh top end uni air filter with lid vents 280 mains and stock pilots...it doesnt have the pull it should in lower gears i tried to rip it up.a hill in 1st and 2nd and it just bogged out but when im on a straight away it opens up and hits powerband through 4th sometimes 5th and 6th it falls on its face..just replaced ignition coil...im in jerseyville illinois and it was 75 degrees yesterday when i rode it...could it be a clutch issue? or main jet?
also it doesnt have enough ass to pop a wheelie either? my old banshee would pull up the front through 4th...the one i have now doesnt have as much done to it but it should still pull up some...its been an ongoing battle with this thing for awhile just need some help guys...it has new reeds as well and got rid of tors forgot to put that in post above
Make sure nubs on flywheel are clean. Check gap at both nubs. Are carbs clean like virgin pussy or 8 mile hooker? Retorque after heat cycles? Even though new top end, what's the compression? What does the spark look like? Have you ohmed coil and plug caps? Check all connections? Clean bare metal at coil mount or seperate ground for it?
see what i dont understand is that it uses the same amount of fuel wot in 1-4 as it does in 5th and 6th right? it doesnt sense what gear it just knows throttle position ill have a chance to take a look at it tomorrow and im gonna try and build a leak down tester or see if the shop by me has one. might have the guy that owns the shop take it for a spin and see what he thinks
well i think i got a couple.bugs figured out...got to looking at ignition coil.and the ground was spliced in 2 spots so i got rid of one splice and cleaned carbs again real good. i can hit wot 3rd 4th and doesnt cut out but 1st and 2ndi lose a cylinder and it follows the plug boot when i move it. havnt checked pickup gap or done compression test thats next on my list and i also might move my main up to 290-300
