exxxtreme Posted March 16, 2013 Report Share Posted March 16, 2013 this is my first banshee. i really have to get on it to get it moving. the guy i bought it from said it was normal and i just bought another banshee for my son and his runs great. i have to get the rps way up almost red line to get it moving. once its moving it screams. i have noticed i get a rough vibration as the rpms come down if im in nutral and rasise the rpms up and let them come down. put in new plugs wondered if maybe one was fouled. put both mix screws a turn and a half out like my sons. doesnt want to idle will die out. i have to give it a little gas to keep running. 1) have to redline rpm's to get moving\ once moving ok tons of top end 2) vibration from engine when rpm's come down from blip in nutral 3)wont idle, have to give it very little gas to keep running please help me, Im thinking maybe jetted wrong, he said he never changed anything... maybe low idle needle clogged... help Quote Link to comment Share on other sites More sharing options...
exxxtreme Posted March 16, 2013 Author Report Share Posted March 16, 2013 choke tube. from the one carb over to the other. rubber hose. its there. is there anything i should know to pull carbs. or same as on a dirtbike. Quote Link to comment Share on other sites More sharing options...
exxxtreme Posted March 16, 2013 Author Report Share Posted March 16, 2013 if im pulling the carbs is there a much better needle to run. or is the stock needle perfect for a stock banshee ( fmf exhaust only upgrade) Quote Link to comment Share on other sites More sharing options...
Juss11 Posted March 17, 2013 Report Share Posted March 17, 2013 Are you sure the clutch aint sleeping? Quote Link to comment Share on other sites More sharing options...
Burt Reynolds Posted March 17, 2013 Report Share Posted March 17, 2013 welcome to the banshee Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted March 17, 2013 Report Share Posted March 17, 2013 if im pulling the carbs is there a much better needle to run. or is the stock needle perfect for a stock banshee ( fmf exhaust only upgrade) Nothing wrong with the stock needle,IMO. Carb slides and bowls are side specific. The slides will go in the wrong carb backwards, and the left bowl is drilled for a choke jet so it has the BB stuck in the hole on the outer bottom. Quote Link to comment Share on other sites More sharing options...
special06shee Posted March 17, 2013 Report Share Posted March 17, 2013 Pull reeds and inspect them! If a reed peddle is cracked or broken you will have zero bottom end or mid range Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted March 17, 2013 Report Share Posted March 17, 2013 While you're cleaning them check jet size and post that up. Could be wrong jetting. Also, every machine is different, all things being equal, one might like 1 1/2 turns, the next 1 3/4 turns. It's called tuning. Quote Link to comment Share on other sites More sharing options...
