locogato11283 Posted March 19, 2013 Report Posted March 19, 2013 DAJ used to run a strut bar with Rod ends that went from the frame to a bolt hole in the case. Think that was a pretty slick set up. Loco, did you move to solid motor mounts on the under side of the frame as well? I've got adjustable struts underneath both now. Quote
springer Posted March 20, 2013 Report Posted March 20, 2013 You got a picture Tyler? I think tanner wants me to run solid mounts no, i am doing probably what tyler is talking about. same as i have on my bikes now. kinda like mini tie-rods. lets you put tension/preload in the opposite direction of motor torque/twist. Quote
locogato11283 Posted March 20, 2013 Report Posted March 20, 2013 Yea, that. Just a couple heims threaded in an adjustable rod. Quote
camatv Posted March 20, 2013 Report Posted March 20, 2013 i almost bought a cougar twin in a stock chassis. to me the rear end geo is something to be desired. a lil moving things around and the power is transmitted way better than stock geo can manage dont EVER run solid mounts!! they are absolutely HORRIBLE> these motors have NO balancer and after you buid some big ass engine the weights are so far off they shake like crazy. tanner understands my "idears" on the preload.. i do with the lower and side mounts. twist a frame and throw enough chains and you tend to figure a few things out.. Quote
