BLOODRAGE Posted February 28, 2013 Report Posted February 28, 2013 Is it possible to use a spacer plate on a stock cylinder for a 4mil crank? Or is a 4mil jug needed Quote
sheerider11 Posted February 28, 2013 Report Posted February 28, 2013 Listen, I had the plate. Now I'm running cut domes and 4 mil porting. I wasted about 200 not doing right the first time. I was probably down on power with the plate too. The plate is no good at all. There should be no reason to run it. Just do it right the first time. Quote
camatv Posted February 28, 2013 Report Posted February 28, 2013 might be ok if the cyls are totally stock. but in my opinion a decently built 350 can smoke a 4 mill if its screwed up in the build.. the transfer port numbers get all nutty and just dont work at all. Quote
BLOODRAGE Posted February 28, 2013 Author Report Posted February 28, 2013 It's a Athena bbk,if it can't be done then no biggy. I read they were junk but with a lil tlc they should do fine Quote
Colby Posted February 28, 2013 Report Posted February 28, 2013 the athena kit isnt junk ... just not much better than stock cylinders Quote
BLOODRAGE Posted February 28, 2013 Author Report Posted February 28, 2013 Guess I just read too much about em lol. Quote
trickedcarbine Posted February 28, 2013 Report Posted February 28, 2013 Do your self a favor and ditch the plate and have domes cut for the stroker. You will need to have the porting done as well. Don't bother doing it with out port work, because it won't run near its potential and you will just end up taking it apart to do it later any way Quote
BLOODRAGE Posted February 28, 2013 Author Report Posted February 28, 2013 So when u say porting,do you have to lower the transfers to match the stroke? Awhile back I asked chucky at superior sleeve about getting the old stock stroke ss jug I had set up for a 4mil,he said it could be done but it wouldn't idle.pretty much told me what had to be done was to cut the transfers lower and use edelbrock epoxy to lower the top of the transfers and exhaust.am I makin any sence?lol Tony at tdr pretty much said the same,only difference was he said it would be easyer with a degree wheel Quote
slobanshee Posted February 28, 2013 Report Posted February 28, 2013 Sounds like you called the wrong people... Quote
sprinklerman Posted February 28, 2013 Report Posted February 28, 2013 Sounds like you called the wrong people... If he called TDR and actually explained himself (better than he types on here) then he called the right guy. Tony knows his stuff.. Quote
BLOODRAGE Posted February 28, 2013 Author Report Posted February 28, 2013 I'm on a cell so bare with me 1 Quote
