sheerider11 Posted January 18, 2013 Report Posted January 18, 2013 Leaned out. I'm on my phone and can't get a good big pic, but it looks like it just ran lean. The crank is blueing from the lack of lube. Quote
papasmurf96 Posted January 19, 2013 Author Report Posted January 19, 2013 thats the only spot in the crank that is blued where it rubbed the case, it was jetted pretty rich and running 32:1 seems kind of unlikely that it was lean but i could be wrong, im just trying to figure out where i need to go from here besides a top end, is the crank still usable being blued like that i mean i just need a little insight on what to do from here, thanks guys Quote
sleeper06 Posted January 19, 2013 Report Posted January 19, 2013 Cranks separate all the time,some can be fixed,that thing clearly was getting hot,IMO your compression should not have dropped that drastic in such a short time if everything was clearanced rite and there was no air leaks heating the death out of it Quote
sheerider11 Posted January 19, 2013 Report Posted January 19, 2013 Well it really sucks that the motor is apart. I would have said to do a leak down to eliminate an air leak. Could be an air leak or a fuel starve issue. You said it's freezing there now. Did you jet for the cold? I wouldn't reuse the crank as is. I'd send it out and get it checked and new bearings put on. It really can be a list of things that did this tho. But with the motor apart it is harder to tell Quote
papasmurf96 Posted January 19, 2013 Author Report Posted January 19, 2013 it was not ridden in the cold i was just too lazy to go outside and rip it apart when it was colt it was around 55-60 degrees the day i went to ride and thats usually when it runs best i found a possible issue, one of the lips on the crank seal was bent up i guess the guy who built the motor for me either got a little careless or it was just a fluke thing im uploading the pictures now. Quote
papasmurf96 Posted January 19, 2013 Author Report Posted January 19, 2013 here is everything apart, any guesses on what caused the flat spot on just the right piston? Quote
papasmurf96 Posted January 19, 2013 Author Report Posted January 19, 2013 also does anyone have any recommendations on who to send the crank to, im thinking of re sleeving jugs to standard size as well as doing an aggressive trail port, wiseco pistons and etc., having crank trued, welded, and new bearings. also which bearing should be used? thanks for the help guys ive had two strokes before but this is my first banshee so im kinda flying blind here, and thanks agin everyone Quote
papasmurf96 Posted January 19, 2013 Author Report Posted January 19, 2013 here is the blown crank seal Quote
Finch Posted January 19, 2013 Report Posted January 19, 2013 wildcard does good crank work. no worth sleeving just post a wanted ad for some stock cyls and you can get some cheaper then a sleeve and more reliable Quote
thrill-billy85 Posted January 19, 2013 Report Posted January 19, 2013 Your crank bearings are done. The closed plug gap is from your piston kissing it on the up-stroke. Good luck man Quote
thrill-billy85 Posted January 19, 2013 Report Posted January 19, 2013 Jeff at F.A.S.T for crank repairs. Quote
Jereme6655 Posted January 19, 2013 Report Posted January 19, 2013 I would send my crank to Jeff at FAST Racing (Farmandsandtoys.com) Those pistons look like they've fought through some detonation.........and there is a picture of your crank that shows a close up of the spot it was rubbing against the cases...but what the HELL is on the crank itself. it almost looks like your pistons started to come apart as tiny pieces and stuck themselves to your crank. my guess.... crank seal failed (that looks to be the cause with that folded lip) and it leaned out your motor.......pistons got hot and she started to detonate and from there it just couldn't take it.... wouldn't surprise me if your crank bearings are all shot. Look around on the For Sale Section.....as sleeving these cylinders is very expensive. A lot of times you can find really good deals from us trying to offload stuff that's just sitting on our benches. Hell you may even be able to find a set of already ported cylinders....wind up cheaper that way. Also....if they're not ported, you can save some $ if you purchase them off of someone here and just have them shipped directly to the builder of your choice. Jereme Quote
BigRed350x Posted January 19, 2013 Report Posted January 19, 2013 For the cost of a crank rebuild you can just get a new crank. Junk the cyls and get some aftermarket cylinders and some custom domes. Jared Quote
421alkybanshee Posted January 19, 2013 Report Posted January 19, 2013 For the cost of a crank rebuild you can just get a new crank. Junk the cyls and get some aftermarket cylinders and some custom domes. Jared X2 Quote
