I wonder if you can test the spark plug wires if they are working 100% and also if my choke is working because mine does not stay in place, i have to hold it out aswell as being a bitch to start.
Needing to hold it out has nothing to do with it working it just means it is getting worn where teh spring rides and will not hold it out any longer. That is a real common problem to have with stock carbs.
But i mean to see if it actually does what it should do.
best way to check spark put your finger in the end and kick it over.
Is this a joke?
I agree this is fool proof!!
To do it right you have got to give it a really firm kick when you do it otherwise it will not work.
It only works if your thumb and index finger are wet. Spit on them a lil bit and hold the wire with those. Make sure u test both sides.
Sent from my SGH-T679 using Tapatalk 2
