ric-ross1 Posted January 10, 2013 Report Posted January 10, 2013 She blew up last sunday, was going slow and it locked up, wont kick over nothing took it apart and saw it broke a skirt and also broke the big end of the connecting rod. Spark plugs where a dark brown/black color. Sometimes out of nowhere she would backfire, here are my mods: Was stock bore k&n open lid filter fresh hone fmf pipes 27.5 pilot 280 main Needle clip in the middle Air screws 1.5 turns out Quote
okbeast Posted January 10, 2013 Report Posted January 10, 2013 Looks like your crank got EXTRA roasty toasty and the bearing probably seized, went downhill from there. Quote
ric-ross1 Posted January 10, 2013 Author Report Posted January 10, 2013 Both of them were smoking and everything felt normal when i put my had on the exhaust. How about the color on the brow piston?? normal??. The other piston had alot of shaving and stuff on it thats the one that broke the skirt. By roasty toasty you mean maybe old and kinda siezed and messed up due to what? lubrication? poor maintnance from the previous owner? Quote
ric-ross1 Posted January 10, 2013 Author Report Posted January 10, 2013 32:1 ratio with 93 oct and yamalube. Quote
wfobasheeboy Posted January 10, 2013 Report Posted January 10, 2013 So when you say fresh hone. You just competed ring job on it? If so you my of not clean all the honing grit out of the CYL before you put it back together. Just a guess? Quote
ric-ross1 Posted January 10, 2013 Author Report Posted January 10, 2013 i bought the motor blown i got a crank for it and hone to the virgen jugs and put new wsm 64.00mm pistons with new rings and it blew up last sunday now the jugs are now 64.5 with wiseco pro lights have to pick them up today from the shop and i get the crank tomorrow. I ran her couple times with no issues but sunday i was on her for 2 hrs of hard riding when this happened. Quote
Surfrjag Posted January 10, 2013 Report Posted January 10, 2013 What was piston wall clearance? Cast pistons notoriously break if they have to much. Quote
BLOODRAGE Posted January 10, 2013 Report Posted January 10, 2013 my bro's banshee's crank looked the same.his grenaded from a air leak. Quote
ric-ross1 Posted January 10, 2013 Author Report Posted January 10, 2013 What was piston wall clearance? Cast pistons notoriously break if they have to much. To be honest i think thats what it was i could move the piston a little when they were in the jugs, didnt exactly measure it i took them out and threw the broken one in the table, but the way the crank broke the connecting rods is the exact same way it had when i bought the motor blown but both happen on the opposite side. my bro's banshee's crank looked the same.his grenaded from a air leak. Good to know, i need to see all the options and start counting which ones might have caused it. Thanks Quote
wfobasheeboy Posted January 10, 2013 Report Posted January 10, 2013 Did you do a pressure test after you put it all back together? Quote
BLOODRAGE Posted January 10, 2013 Report Posted January 10, 2013 on my bro's banshee the airleak was caused by the fuel line, it rubbed a hole on the cross over tube for the carbs Quote
ric-ross1 Posted January 10, 2013 Author Report Posted January 10, 2013 Did you do a pressure test after you put it all back together? To be honest my home made tester was leaking itself so i didnt pay attention and didnt do it( I know i paid for it) The way it looks you might of had some major air leaks... Maybe not sure, going to make a better one tomorrow when i put it together. on my bro's banshee the airleak was caused by the fuel line, it rubbed a hole on the cross over tube for the carbs I will check that out tonight when i get home, but it looked fine. Thanks Quote
