Heres a really dumb question but lets say you wanted to perform a comp test with an engine on the bench. Do you need to have the carbs installed or just the reeds and intake? What about the exh? Would the reading be lower?
Need the motor in the bike, exhaust mounted, carbs and air box hooked up. Kick by intervals of 6 till you do 60 kicks. Check reading. Start bike warm it up and begin the process again until you do 60 kicks per side
What??
Ya need the plugs in thats about it. I can't see you being able to kick it over without being in the bike though. Kick it untill you get a max reading it will only go so high.
If I wrong someone please say lol
So I've been doing it wrong all these years. I stopped at 59 every time. No wonder it runs like shit.
LOL I am assuming that is a joke? Pretty funny if you ask me.
 You could do it on the bench just fine with just the reeds and intakes installed as long as you have some way figure out to kick it over. No need for exhaust or anything else. Just let us know how you decided to kick it over hard enough to do this.
Higher than normal cranking speed will raise compression readings. But you guys are right about trying to kick over a loose engine good luck. Time to drag the spare frame into the garage. Thanks for the input.
