I'm about to have JD cut me some rotors with a bit more diameter so that the entire pad is used. Should make even more stopping power. Once I have the diameter I'll post it here.
My Laeger pro-trax front end uses larger diameter wave rotors than OEM.
Plus I run YFZ dual piston front calipers and braided brake lines.
With my setup the caliper is moved further away from the spindle so the clearance with 4-1 wheels is close.
The stopping power over a stock Banshee and pretty much every other bike I have ridden is night and day better and stronger.
I can use a single finger on the brake lever and have effortless control on high speed slow downs. It will do stoppies easily too if you have enough front wheel traction.
Sent from my DROID RAZR using Tapatalk
  • Like 1
08 yfz450 calipers on banshee
hp what u running on the rear?
Sent using Iphone5 onTapatalk
Stock still
ragun, are you going to be running the standard 3/2 offset rims or going to 4/1 offset rims with the +3 arms?
I want new wheels and tires. So what do you recommend and why?
