SpeedRacer88 Posted December 7, 2012 Report Posted December 7, 2012 anybody ever take the str8 cuts off a spring loaded basket and install on another basket?I been having problems out of my clutch so i'm thinking of swapping baskets with a diff billit one Quote
trickedcarbine Posted December 7, 2012 Report Posted December 7, 2012 Totally doable. One thing I just encountered was mounting a set of hinsons on to my PE/Magnum Billit basket, was that the bosses which hold the cushions and screws for the backing plate were about 10 thousandths to tall. So it took a little 220 grit on the granite block to get it milled down. Quote
Finch Posted December 7, 2012 Report Posted December 7, 2012 spring loaded basket doesnt have cushions... Quote
SpeedRacer88 Posted December 7, 2012 Author Report Posted December 7, 2012 i'm lost here bud i just took my gears off my hinson and they look totally dif than stock. I'm hoping someone who did the swap before will chime in Quote
SpeedRacer88 Posted December 7, 2012 Author Report Posted December 7, 2012 i wasn't aware that the gears where diff and i already ordered a pe basket. I am constantly breaking fibers and i already swapped out everything else out. Also wasn't aware u cud get jus the hinson basket. Tricked are you saying the bosses on the PE basket are too tall? Also i tried to line my old gears up and the bolt holes are like an inch off Quote
SpeedRacer88 Posted December 7, 2012 Author Report Posted December 7, 2012 Yeah i had it for like 5 years it was in the bike when I got it but look at these gears they look totally diff Sent from my Galaxy S3 using Tapatalk 2 Quote
trickedcarbine Posted December 7, 2012 Report Posted December 7, 2012 My gears were off the "Billit Proof" basket I got from STROKING. They were cushioned not sprung. I guess your situation is a bit different. You will have to get the actual spring basket from Hinson to run those. I have seen guys machine the same gear set you have to make them work, but that requires access to the right equipment. Quote
trickedcarbine Posted December 7, 2012 Report Posted December 7, 2012 As far as the Hinson gears on the PE/Magnum basket, the problem is the actual height of the bosses on the back side of the basket where you screw the backing plate on. They just need a bit of grinding to get through the hard annodizing and then put some 220 grit on a granite top or glass. Move the part in an figure 8 till the gear set will fit tight. Let me know if you need more details. If it were me I would just pony up for the basket that goes with your gear set. Quote
SpeedRacer88 Posted December 7, 2012 Author Report Posted December 7, 2012 Have no problem buying the right basket I just was unaware they were diff I already ordered a pe basket.... Guess I'll just run stock gears Sent from my Galaxy S3 using Tapatalk 2 Quote
trickedcarbine Posted December 7, 2012 Report Posted December 7, 2012 Some one may pay you for that PE basket what you purchased it for. On another note, how is the lock up tuning coming? Did I get you close? Quote
SpeedRacer88 Posted December 7, 2012 Author Report Posted December 7, 2012 damn close i ended up adding one ball to the "progressive" grooves, because i had a lil more slip than i wanted. All good now on the lockup. Quote
SpeedRacer88 Posted December 7, 2012 Author Report Posted December 7, 2012 yea my straights / hinson set up was bought back in 06 i think... so it has quite a few years on it... the basket is just starting to groove now.... ill be buying a new hinson with springs... i think they quoted me 350 total.. the springs alone are 89$ yeah my basket as been in a 10 super cub then my 4 cub and now my 10 serval she had miles on her. She was starting to groove i ignored it then i broke fibers. i tried to smooth it out but the broke fibers made a couple realy deep indentions, i think she toast now. i'm prolly just gonna throw the hole hinson setup with gears on ebay... Quote
Z400Banshee Posted December 7, 2012 Report Posted December 7, 2012 Does anyone know if 2.54 straight cut gears will work with this spring loaded basket? I just called hinson and they had some guy answer that didnt know shit and just sounded stoned Quote
Finch Posted December 7, 2012 Report Posted December 7, 2012 better call back and get a better answer. you wouldnt want that ratio imo unless your doing asphalt Quote
Z400Banshee Posted December 7, 2012 Report Posted December 7, 2012 I do plan on doing some rode riding with this quad thats why i want to use that ratio. I'm going to call back tomorrow to talk to someone else because it sounded like i was talking to beavis and butthead Quote
