BLOODRAGE Posted November 3, 2012 Report Posted November 3, 2012 need the 2 that bolts up under the motor Quote
4wheeling Posted November 4, 2012 Report Posted November 4, 2012 go buy two metric fine thread bolts at a place that has that sort of stuff in your town. Quote
BLOODRAGE Posted November 4, 2012 Author Report Posted November 4, 2012 i did and they wont fit Quote
5150banshee Posted November 4, 2012 Report Posted November 4, 2012 Where are u located.... Usually u can order them from Yamaha if u don't know the size a lil pricey probably 3-4 bucks a bolt. Sent using Tapatalk Quote
BLOODRAGE Posted November 4, 2012 Author Report Posted November 4, 2012 3-4 bucks a bolt is better then 25-30 on egay. do you know what mm the threads are? im in a really small town in alberta canada Quote
old put-put Posted November 4, 2012 Report Posted November 4, 2012 Go to Rockymountain Atv, yamaha oem parts, $2.82 each. Quote
BLOODRAGE Posted November 4, 2012 Author Report Posted November 4, 2012 $35.64 shipped to canada ill go over to the only place that sells bolts tomorrow after work and see if they can get somthing that will fit, this is bs,cant take the shee out for a winter ride without em Quote
AdrenalineJunky Posted November 4, 2012 Report Posted November 4, 2012 I might have some if you still need them? The 2 bolts that are for the lower motor mount bolts or for the 2 bolts that bolt the stabilizers under the bottom of engine? Quote
BLOODRAGE Posted November 4, 2012 Author Report Posted November 4, 2012 the 2 bolts that bolt from the stablizer to the bottom of the engine,not the ones that bolt from the stablizer to the frame shit can get confusing fast lol pm me how much then we will go from there Quote
AdrenalineJunky Posted November 7, 2012 Report Posted November 7, 2012 I have the bolts for the front lower frame to motor mounts. They should be like 10x1.5 metric bolts bro. Should be able to find some at a hardware store. If I had them i'd send them to ya. Sorry bro! Quote
notsed Posted November 7, 2012 Report Posted November 7, 2012 m10x1.25, same as the foot peg bolts, might be hard to find locally, i would order some online like here http://www.ebay.com/itm/2Pcs-Fine-Thread-Hex-Cap-Screw-Bolt-M8-x-1-M10-x-1-M10-x-1-25-/120813211809?pt=LH_DefaultDomain_0&var=420052393156&hash=item1c210750a1 Quote
