turbosrt4 Posted August 20, 2012 Report Posted August 20, 2012 i bought a banshee the right front wheel is cambered out -----leaning out im asumming something is bent the frame is not bent ,how hard is it to bend a spindal Quote
5150banshee Posted August 20, 2012 Report Posted August 20, 2012 Can also check the tie rod not sure how hard it is to bend a spindle there aluminum or check the mounts also Quote
ClayAiken Posted August 20, 2012 Report Posted August 20, 2012 Dont bad ball joints cause leaning? Quote
turbosrt4 Posted August 20, 2012 Author Report Posted August 20, 2012 yea they do buts its not the ball joint Quote
jsinar Posted August 20, 2012 Report Posted August 20, 2012 If it is bent, I've got a right spindle I'm not using, I bought a pair because I needed a left one.. Quote
turbosrt4 Posted August 20, 2012 Author Report Posted August 20, 2012 If it is bent, I've got a right spindle I'm not using, I bought a pair because I needed a left one.. how much Quote
jsinar Posted August 21, 2012 Report Posted August 21, 2012 $30 shipped sound fair? It almost looks like that lower arm has a little bit of a bow to it..? Before you blame the spindle, pull the hub off and look at the spindle dead on, the shaft should be perfectly square with the spindle itself, On my left side, mine was the opposite, it had negative camber, the shaft was bent up just a little, barely noticible until you got everything put back together.. Quote
ClayAiken Posted August 21, 2012 Report Posted August 21, 2012 $30 shipped sound fair? It almost looks like that lower arm has a little bit of a bow to it..? Before you blame the spindle, pull the hub off and look at the spindle dead on, the shaft should be perfectly square with the spindle itself, On my left side, mine was the opposite, it had negative camber, the shaft was bent up just a little, barely noticible until you got everything put back together.. That does look like it is bowed not sure maybe were seeing things. Quote
sheerider11 Posted August 21, 2012 Report Posted August 21, 2012 How are the bushings in the arms? I know they won't make it go out that much, but it doesn't hurt to check them Quote
toytech Posted August 21, 2012 Report Posted August 21, 2012 here it is it looks like the frame is tweeked where the front lower a arm mounts. could just be the angle of the pic though. Quote
hoppedupandcutdown Posted August 22, 2012 Report Posted August 22, 2012 It looks like you right spring is compressed more that the left, and the left upper control arm is at a steeper angle than the right. is the right shock stuck compressed? Quote
